Missing POST Parameters
I have a virtual server with an iRule that redirects traffic by hostname. E.g.
when CLIENT_ACCEPTED {
  switch [string tolower [HTTP::host]] {
    somesite.myawesomedomain.com { virtual vs_child_somesite }
    someothersite.myawesomedomain.com { virtual vs_child_someothersite }
This normally works great, but when a POST is sent to any of these servers, I don’t see the POST data and the Content-Length is 0.
Running tcpdump on the web server to capture the POST requests reveals the issue:
sudo tcpdump -s 0 -A 'tcp dst port 80 and (tcp[((tcp[12:1] & 0xf0) >> 2):4] = 0x504f5354)'
POST /signin HTTP/1.1
host: somesite.myawesomedomain.com
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
Accept-Encoding: gzip,deflate
Accept-Language: en-US,en;q=0.8
Cache-Control: max-age=0
Content-Type: application/x-www-form-urlencoded
Cookie: _session=s1092tyahglskghado1i2
Origin: https://somesite.myawesomedomain.com
Referer: https://somesite.myawesomedomain.com/signin
User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/38.0.2125.122 Safari/537.36
X-Forwarded-For: 1.2.3.4
X-Forwarded-Port: 80
X-Forwarded-Proto: http
Content-Length: 0
Connection: keep-alive
Everything works fine if I go around the F5, straight to the server itself:
host: somesite-direct.myawesomedomain.com
Content-Length: 178
utf8=%E2%9C%93&authenticity_token=kflcZfoGoig%2ByR6U0x3Rw%2BO6qbjpRlUVGIBK0gZmWWQ%3D&user%5Bemail%5D=steve&user%5Bpassword%5D=mycoolpass&user%5Bremember_me%5D=0&commit=Go
Just out of interest, are you certain this irule works? The HTTP:: host command doesn’t have CLIENT_ACCEPTED as a valid event. What about if u use HTTP_REQUEST??
Thx @nathan. Typo in my example, I am actually doing that in a HTTP_REQUEST block… on another note. I can’t seem to edit my post -- “Uncaught Sys.WebForms.PageRequestManagerParserErrorException: Sys.WebForms.PageRequestManagerParserErrorException: The message received from the server could not be parsed. Common causes for this error are when the response is modified by calls to Response.Write(), response filters, HttpModules, or server trace is enabled.”
Thanks for clarifying. Does a tcpdump on the bigip offer any useful info?
Great idea, Nathan. Looks like we lose the POST data between the last F5 virtual server and the pool member. The traffic goes to vs_parent_somesite_443 (where the rule above lives) → vs_child_somesite → pool member …/Common/vs_parent_somesite_443 18:41:00.710491 IP 1.2.3.4.47813 > 3.4.5.6.http: P 0:945(945) ack 1 win 4380 in slot1/tmm1 lis=/Common/vs_child_somesite …E…Z.@…b. .=…j…P…5Yi`U… $..&$..&POST /signin HTTP/1.1 Host: somesite.myawesomedomain.com Connection: keep-alive Cache-Control: max-age=0 Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8 Origin: https://somesite.myawesomedomain.com User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/38.0.2125.122 Safari/537.36 Content-Type: application/x-www-form-urlencoded Referer: https://somesite.myawesomedomain.com/signin Accept-Language: en-US,en;q=0.8 Cookie: _session=s1092tyahglskghado1i2 X-Forwarded-For: 1.2.3.4 b2 utf8=%E2%9C%93&authenticity_token=kflcZfoGoig%2ByR6U0x3Rw%2BO6qbjpRlUVGIBK0gZmWWQ%3D&user%5Bemail%5D=steve&user%5Bpassword%5D=mycoolpass&user%5Bremember_me%5D=0&commit=Go …/Common/vs_child_somesite 18:41:00.710914 IP myexternalip.somesite.com.47813 > a-pool-member-ip.http: P 2845897884:2845898674(790) ack 1803219730 win 4380 out slot1/tmm1 lis=/Common/vs_child_somesite …E..JZ.@…y … …P…kz…0… $..&..q.POST /signin HTTP/1.1 Host: somesite.myawesomedomain.com Connection: keep-alive Cache-Control: max-age=0 Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8 Origin: https://somesite.myawesomedomain.com User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/38.0.2125.122 Safari/537.36 Content-Type: application/x-www-form-urlencoded Referer: https://somesite.myawesomedomain.com/signin Accept-Language: en-US,en;q=0.8 Cookie: _session=s1092tyahglskghado1i2 X-Forwarded-For: 1.2.3.4 X-Forwarded-For: 1.2.3.4 …/Common/vs_child_somesite
Can you do a specific conditional check of the host header value against the vlaue you want to use, for e.g.
if { [HTTP::host] equals “the exact string” } { log something }
Test it with a value which is not working. If this conditional is not met when it should, then the Host header value might be URL encoded. So try decoding the URL and do the if test again.
ok, finally figured this out.
turned out to be a stream profile on the virtual server running the iRule. in 11.2 it’s fine to have 2 regular expressions concatenated without a space. e.g.
@http://somesite\.@https://somesite.@@http://someothersite\.@https://someothersite.@
but in 11.6, this silently breaks and sets content-length to 0
using this works in 11.6:
@http://somesite\.@https://somesite.@ @http://someothersite\.@https://someothersite.@
if someone from f5 is reading this, that syntax error should raise an exception or log something somewhere
glad it’s sorted. good work
for sure, thanks for all your help @nathan!
Thanks for sharing!!
