missing HTTP_RESPONSE_DATA when Web Accelerator is enabled
We’ve written a custom iRule based on the anti-phishing iRule posted on DevCentral (very helpful, BTW) to inject some custom HTML content and it is working well. However, we ran into an issue when running this iRule against a Virtual Server that has web accelerator. The issue we saw (from debug log entries) is that the HTTP_RESPONSE_DATA section seems not to fire.
In talking to an SE, it was suggested that this could be due to the fact that Web Accelerator crates a “hidden” virtual server. Has anyone run into this? Has anyone gotten the anti-phishing iRule to work with Web Accelerator turned on?
Much thanks!
//Joe
Hi Colin,
Here is a update in case you were’ tracking this:
So the mystery has been solved, but the issue turns out to be completely different than expected. After much experimentation and luck, I was able to get the CreditCardScrubber iRule working against the test chunking site by change the HTTP::collect parameter from the default 4294967295 (4+ gigs) to an apparently more manageable 1000000000 (1 gig).
I don’t know for sure why, but I suspect that some memory allocation is failing with the larger collect parameter. I went to 3 gig and was able to see intermittent failures to get HTTP_RESPONSE_DATA. I found 2 gig to be very consisten in being successful, but set it at 1 gig to be safe. Unlikely any HTML page will be 1 gig in size in any case.
I will also post a separate message that better describes the core issue.
Thanks again for your help!
//Joe
Thanks very much for the update!
Colin
