Hi, I’m trying to configure SSL offloading with IP-HTTPS. I followed the guide written by Richard Hicks (https://directaccess.richardhicks.com/2013/07/10/ssl-offload-for-ip-https-directaccess-traffic-from-windows-7-clients-using-f5-big-ip/)
I’m getting an error message (No Certificate on gui under statistics and Handshake failures in the log)
The certificate is a public certificate of authority generated for the IIS server and imported separately cert, key, chain.
Do I need to create a certificate from a CSR generated on the F5 with the public chain and key for this to work?
Is there any other option I need to tick?
Your help is much appreciated,
Many thanks
Damir
