Mirroring Setup General Knowledge
Couple questions about Mirroring on HA Pair Do you only enable or use mirroring for persistence? We use snat or snat pools on most every VIPs and are one arm environment mostly.
4 Mirrioring Settings/options Device Cluster VIP SNAT Persistence Profile
Usually have muptile Vlans and floating and nonfloating SelfIPs Under Cluster options Netwrok Mirroring Within Cluster (This IP will be Different then the Self IPs and VLans) Primary local and secondary local.
VIP Normally required enable connection Mirroring?
Local trafic>> Address tranaslation>>>Snat list>>> New Snat== Check the Stateful failover Mirror ? When should i use this no clue???
Persistence Connections ? DO you have to enable this to mirror Persistence connections Universal and other persistence profiles Mirror Persistence check
