Hi all,
Need some advice on how to achieve the below with bigip.
Current setup :
* Each customer gets 2 DNS vips and one HTTP VIP and each HTTP VIP is limited to say 100 concurrent connections.
* We use host-range feature of ServerIron to define the DNS VIPs for the entire C class of IPs. For ex
server virtual x.x.1.2
host-range 250
port dns
bind dns rs1 dns rs2 dns
server virtual x.x.2.2
host-range 250
port dns
server real rs1 192.168.1.2
host-range 250
port dns
server real rs2 192.168.2.2
host-range 250
port dns
* what this does is if a DNS request came to DNS VIP x.x.1.100, chooses a real server and translates the destination ip to 192.168.1.100. 192.168.1.2 to 192.168.1.254 is bound on rs1 and similarly 192.168.2.2 and 192.168.2.254 is bound on rs2.
* the bind real servers use views with the destination IP filter - each view loads a single zone but the resource records are different for each view - i,e there is a wildcard A record which returns diff IP address for each view.
* the HTTP vips are defined normally - for ex
port http max-conn 100
bind http rs1 102 rs 102
* This is because the real server port is teh unque identifier for the customer and to serve diff doc root.
Bigip setups :
For DNS :
From what i can understand - there are two ways
1. seems like the DNS config is possible with a wildcard virtual server and npath routing - but we use the bigip as the default gw on all the real servers and npath routing will not work in such cases.
Pros : cleaner config & simple implementation
Cons : Our network is currently setup to use the bigip as default gw and we would like to retain that config possible
2. create one vip, one pool and N nodes (N= no of web servers) for each NS vip - so for 250 customers, this translates to 250*2 vips, 250 pools, and 250*6 nodes.
pros: meets the requirements
cons : ugly config and what abt performance impact with that many objects ? We are looking at having around 2000 customers this way
For HTTP:
* No issues here - with wildcard virtual server and a irule to insert the VIP which received the orig request solves the problem.
** but dunno how we can limit concurrent http connections to each destination ip - possible with a irule ?
I would like to keep the bigip config simple and yet retain similair functionality as our existing setups with serveriron. Any ideas on what methods i can use to achieve this and yet keep config simple and performance intact ?
Dushyanth
