Anyone have run into v11.5 issue, where all the iApp templates missing on standby bigip, but appears on active bigip.
mcpd[6346]: 01070734:3: Configuration error: /Common/f5.citrix_presentation_server: line 0,1: Script (/Common/f5.apl_common) could not be found
Tried to configsync both directions but fails.
Anyway to remove default iApp from Active completely, or add to Standby, so the configsync works?
Regards,
I would suggest opening a case, it is odd that f5.citrix_presentation_server is missing from one of your BIG-IP’s since it is an iApp that is included with TMOS.
I just upgraded to 11.5.3 from 11.4.1. My primary BigIP is missing all the templates, but if you go to iApp / Application Services, you can select the iApp from that list. They just don’t show up in the iApp / Templates page.
Everything is fine on the standby BigIP.
I plan on opening up a ticket on this unless someone has already found a solution.
Jim
