migrate from 4.X to 9.X iRules
Anybody can refer me to a document (if exists) what is best way to migrate iRules from 4.5 to 9.X? Are there any recommendations?
Here is example of one of the rules:
if (http_header(“SSLClientCipher”) matches_regex “bits=128” or “bits=256”) {
if (exists http_header(“SSLClientCertStatus”)) {
if (http_header(“SSLClientCertStatus”) contains “OK”) {
use pool eids.mymerchantoffice.com
else {
redirect to “https://%h/main/MyPortfolio/Eids.aspx?certinstalled=6”
else {
redirect to “https://%h/main/MyPortfolio/Eids.aspx?certinstalled=3”
else {
use pool client_info
