meta refresh to 302s
I have the following iRule
However sometimes we receive the following error
Do you know why?
May 20 10:56:32 tmm tmm[1019]: 01220001:3: TCL error: Rule refresh_to_redirect_4 - Operation not supported (line 8) invoked from within “HTTP::header replace “Connection” “Keep-Alive””
iRule to convert meta refresh statements to 302s
when HTTP_REQUEST
if {[HTTP::uri] contains “.pt?”}
set checkContents 1
if {[HTTP::version] eq “1.1”}
if { [HTTP::header is_keepalive] }
HTTP::version “1.0”
else
set checkContents 0
when HTTP_RESPONSE
if {($checkContents>0) and ([HTTP::header Content-Type] starts_with “text/html”) and ([HTTP::header exists “Content-Length”])}
set content_length [HTTP::header “Content-Length”]
if {($content_length>=400) and ($content_length<=600)}
HTTP::collect $content_length
else
set checkContents 0
when HTTP_RESPONSE_DATA
if {($checkContents>0) and ([HTTP::payload] contains "meta HTTP-EQUIV=\“REFRESH\” CONTENT=\“0;”)}
set urlresponse [findstr [HTTP::payload] “URL=” 4 {">}]
if {$urlresponse!=“”}
HTTP::payload replace 0 $content_length [format “” $urlresponse]
HTTP::release
Off the top of my head I’d guess that some of the traffic is missing a Connection header and the command is erroring out with a message that’s less than appropriate. I’d try adding some logging statements around the line in question to see what’s coming through when you see those errors.
Colin
I think HTTP::header replace will just insert the header if it doesn’t exist already and not generate an error. Iis there another iRule on the VIP which is issuing a redirect or otherwise conflicting with the HTTP header replace command?
Aaron
