I need to write an iRule that will track what cookie values are assigned by the back end servers and to which user IDs and store them for a certain period of time. This is a multi-part problem, and I don’t know where to begin.
1. A global variable is one thing, but how do you dynamically create and maintain a table?
2. How can I keep a counter on the age of a value in this table and remove it after, say, 60 minutes?
My thought is that I could have three sets of values in the table: one with cookie values, the second with corresponding user IDs (which I’ll extract from the payload), and the third with a clock scan at the time I add the values. I’ll just have to add some logic somewhere else to clean up or something.
Thoughts? Is there an easier way?
1. session command
2. session command
3. Click here
Don't allow data to be chunked
if { [HTTP::version] eq "1.1" } {
if { [HTTP::header is_keepalive] } {
HTTP::header replace "Connection" "Keep-Alive"
HTTP::version "1.0"
when HTTP_RESPONSE {
if {[HTTP::cookie exists myCookie]}{
trigger collection for up to 1MB of data if cookie exists
if {([HTTP::header exists "Content-Length"]) && ([HTTP::header "Content-Length"] <= 1000000)}{
set content_length [HTTP::header "Content-Length"]
set content_length 1000000
if { $content_length > 0 } {
HTTP::collect $content_length
when HTTP_RESPONSE_DATA {
grab client ID to use as session table entry key
set clientID [findstr [HTTP::payload] "clientID=" 9 &]
if {$clientID != ""}{
if key value found, add session table entry with 300 sec timeout
session add uie $clientID [HTTP::cookie myCookie] 300
HTH
/deb
Thanks, deb. That got me going.
