Member Name not visible when adding Virtual Server to Pool
Hi all,
I’ve got what I hope is quite a basic question.
I’ve created a new Virtual Server with fairly basic configuration. I’ve named it, assigned an IP and an SMTP Service Port.
When I view the properties of the VS, it show’s the name that I’ve assigned it. But when I add the VS to a Wide IP Pool as a Member, it shows the address I assigned, but the Member Name field is completely blank. If I click on the address to show general properties within Global Traffic> Pools> ‘Created VS’, again the Member Name field is blank.
This is on a 6400 LTM with the GTM module. Running Vers. 9.2.3 Build 58.0
Any idea?!
Thanks,
moved your topic to the advanced design/config forum…I’ve seen this before when virtual server discovery was enabled and there were conflicts with the name. I’d open a support case on this issue.
OK thanks.
Anybody else come across this before?!
