MD5 not match (BIG-IP V. 10.2.4)
Hi
I’ve some question about iso image of BIG-IP v. 10.2.4 It’s said “111e6ba3dd592a6d0335326f19a2e125 BIGIP-10.2.4.577.0.iso” is md5 of this image file but how many time I tried to download image I got “DECA3DBD76004ABF4479DFE3551C7516”
Is md5 on web download.f5.com wrong? or else? Thank you
After you upload the 10.2.4 image to your BIG-IP, run this from CLI:
md5sum
If the output of this doesn’t match what F5 has published on their downloads page, then you’ll need to download the file again. I’ve never encountered an md5sum mismatch between what F5 posted on their page and what it checks out to after downloading.
Is there another host/network you can try downloading the file to, if it’s a problem related to the host/network that you are currently on?
interesting, i just did an md5sum on a local image and also got deca3dbd76004abf4479dfe3551c7516, but is also what the .md5 file has for me: deca3dbd76004abf4479dfe3551c7516 BIGIP-10.2.4.577.0.iso
.md5 file from F5 ? So Strange … This is mine when see md5 http://image.ohozaa.com/view2/x8vkFgHQ5yNIQBHo
The current md5sum file on F5’s download portal contains this: 111e6ba3dd592a6d0335326f19a2e125 BIGIP-10.2.4.577.0.iso This mismatch is strange. Teepan, when you upload the code to your BIG-IP device, does the field “MD5 Verified” say “Yes” when you look at the image file in System → Software Management → Image List?
Yeah. When I upload to Software Management It shown “MD5 Verified Yes” But If I want to upgrade from 9.x to 10.2.4 . which doesn’t have software management. When I check MD5, If MD5 shown as below “DECA3DBD76004ABF4479DFE3551C7516” I think it’s ok :smiley:
