mcpd Configuration error: Invalid mcpd context folder not found
I have BIG-IP LTM running 11.2.1 Build 1299 HF12
Today when doing an ops check on my equipment I noticed a solid red status light on my LTM. I looked at the GUI and I received the following errors in System>Logs>Local Traffic (log):
mcpd () Configuration error: Invalid mcpd context folder not found (/Common/dir) mcpd () Configuration error: Invalid mcpd context folder not found (/config) mcpd () Configuration error: Invalid mcpd context folder not found (/config) mcpd () Configuration error: Invalid mcpd context folder not found (/config) mcpd () Configuration error: Invalid mcpd context folder not found (/config) mcpd () Configuration error: Invalid mcpd context folder not found (/config) mcpd () Configuration error: Invalid mcpd context folder not found (/config/user_alert.conf)
All errors have a status code of 01070734
I have checked various logs on the system and cannot seem to find out why this error was generated. To my knowledge, nothing has changed in the last 72 hours on this device.
when logging into the back end and performing the following command:
sys daemon-log-settings list mcpd all-properties I get the following output: sys daemon-log-setings mcpd { audit disabled log-level notice } Any assistance on the matter is greatly appreciated. Thank you
i think it may be better to open a support case.
Did you found the cause for this issue ?
Thanks Patricio
