Is it possible to change the notification message and interval for the Maximum Session Timeout?
Currently it notifies the end user with 1 hour left with a popup bubble. Can that be customized?
in which module? can you share a screenshot?
sorry but don’t you show where you can set the Maximum Session Timeout in your first screenshot?
or do you want to modify the message someone gets after the Maximum Session Timeout value expires?
I want to change the message they get and maybe the frequency they get it like more than just 1 hour before.
Hi ,
So , is it possible to send the notification to the user before the session gets expired, Ex:- If the session length is 24 hours, can we set the APM to send the pop-up at the 23rd hour to the user to notify that the session will be expired in the next one hour .
Hi, Reddy.
Did you manage to find your way to this question?
via Customization > General and then Webtops > name > Text - Web Application Session Time you can make some changes to the texts, but just that.
via Customization > General and then Webtops > name > Branding - Web Application Session Time you can make a change to the Guard time, which it seems is what you are partly looking for.
Thanks boneyard. I found the guardtime field. What does this one do? Current value is 100 I found the text for the max and idle timeout but I don’t see a way to add an additional warning for max session approaching I would like to give multiple warnings at various intervals like 1hr, 30, 15, 10, 5, 1 We have people complaining about be dropped so we want to annoy them with warnings and say not it we warned you…
the guard time is when it will happen for the first time, im afraid you can’t do it repeatedly with a simple configuration toggle or setting.
