I have a scenario where users are running scripts that run through a virtual server but are getting closed after the default 300 second idle timeout. The reason is the script sends commands to the VS to run and waits for a response. At times the jobs finish under five minutes but there are a lot of jobs that run longer which lead to false positives causing errors.
I have increased the tcp idle timout and keep alive temporarily but main question is is there a “MAX” recommended setting for idle timeout and keep alive. I know it can be set to indefinite but I do not know if that is wise as it could lead to port exhaustion.
Any tips would be great,
