matching two classes - iRule 10.2.4
I have the iRule working below with just CLASS-1. I am simply trying to say CLASS-1 OR CLASS-2, but having trouble getting F5 to take it. Do I need to set a variable or something like an elseif?
when CLIENTSSL_CLIENTCERT {
if {[SSL::cert count] > 0}{
if { ! ( [class match [substr [X509:subject [SSL::cert 0]] 3 “,”] equals CLASS-1 ] || {![class match [substr [X509:subject [SSL::cert 0]] 3 “,”] equals CLASS-2 ] } ) } {
log local0. “Client dropped :[substr [X509::subject [SSL::cert 0]] 3 “,”]”
drop
b class CLASS-1 '{
“11111”
“CN=,OU=xxxxx”
“Requestor1”
“cert-subject-name” { “Details” }
b class CLASS-2 '{
“22222”
“CN=,OU=yyyyy”
“Requestor2”
Thanks!
Replace || with &&. It looks like you want both conditions to be met for the connection to be dropped and logged. Therefore you need to AND instead of OR.
Condition 1: ! [class match [substr [X509:subject [SSL::cert 0]] 3 “,”] equals CLASS-1 ]
Condition 2: ! [class match [substr [X509:subject [SSL::cert 0]] 3 “,”] equals CLASS-2 ]
Hope this helps.
No, I’m really looking for an OR condition. I tried && to, and it still throws a PARSE error.
Let me explain a bit more:
b class CLASS-1 '{
“CN=XXXXXX,”
b class CLASS-2 '{
“CN=YYYYY,”
This works:
if { ! [class match [substr [X509::subject [SSL::cert 0]] 3 “,”] equals CLASS-1 ] } {
drop
However when trying to add CLASS-2 as a OR condition I get a TCL error(below iRule):
set X509_subject [X509::subject [SSL::cert 0]]
if { { ! [class match [substr $X509_subject 3 “,”] equals CLASS-1] } || {!([class match [substr $X509_subject 3 “,”] equals CLASS-2] } } {
drop
Apr 5 15:07:55 local/tmm3 err tmm3[6610]: 01220001:3: TCL error: test-iRule - expected boolean value but got " ! [class match [substr $X509_subject 3 “,”] equal" while executing “if { { ! [class match [substr $X509_subject 3 “,”] equals CLASS-1 ] } || {!([class match [substr $X509_subject 3 “,”] equals CLASS-2…”
I got this to work using the following:
set X509_subject [substr [X509::subject [SSL::cert 0]] 3 ","]
log local0. "X509-subject-CN:$X509_subject"
if { ! ( [class match $X509_subject equals CLASS-1 ] || [class match $X509_subject equals CLASS-2] ) } {
log local0. "Client dropped :$X509_subject"
drop
