Puli
1
I need to match below patter in a url and re-direct traffic.
http://www.abc.com/temp/2011/12/temp.html
Am using below code
if { [string match {*/*[0-9]*/*[0-9]*/* } [HTTP::uri] } {
user pool pool1
when run config sync to peer, i get an error saying invalid argument.
if i escape the special characters like
{\*\/\*[0-9]\*\/\*[0-9]\*\/\*} config sync run sucessfully but the url patter does not match.
Any ideas , am ok not using string match if there’s a better alternative.
thanks.
hoolio
2
Hi Puli,
Can you try this:
if { [string match “*/*\[0-9\]*/*\[0-9\]*/*” [HTTP::uri] } {
Only the square braces should need to be escaped if you wrap the pattern in double quotes instead of curly braces.
Aaron
Puli
3
thanks aaron,
works perfect ! appreciate it.
Puli
4
Small problem facing with the match.
Its also matching
http://www.abc.com/temp/barton2011/12/temp.html
How can i make it so it only strictly matches number and ignores letter in it ?
thanks.
Can you provide a few more examples of URIs you do want to match a few that you don’t?
Thanks, Aaron
Puli
6
Hi aaron,
i fixed it, i had a wildcard in front that matching all characters followed by numbers. Below is the modified one
From
to
if { [string match “*/\[0-9\]*/*\[0-9\]/*” [HTTP::uri] } {
I had to match only url of specific type
http://www.abc.com/temp/\[digits]/\[digits]/temp.html
thanks for the support.
Appreciate it.
