matching and/or replacing + sign in STREAM::expression
I am using the ProxyPass v10/v11 iRule (link) to direct and rewrite http URIs and response payloads. Although I set everything up correctly and the irule builds the correct STREAM:expression according to my needs the stream command does not execute after the first + sign. I have tried escaping it with various methods (classical backslash, unicode escape sequences) but none worked so far. Did anyone had the same situation? I am pasting an example URI to be matched in content rewriting.
Original: /TR+tr/some_example_http_path/some_example_file.ext
Needs to be rewritten to: /some_example_http_path/some_example_file.ext
Please try this:
    HTTP::header remove Accept-Encoding
    STREAM::disable
when HTTP_RESPONSE {
    STREAM::expression {@/TR\+tr@@}
    STREAM::enable
Kevin hi,
I just had a chance to try your response. However the Accept-Encoding header is removed by ProxyPass iRule so it can rewrite/modify responses. Hence it is not applicable. However I will write a simple irule just to test the particular response modification. I will update the results accordingly. I am open to new suggestions at the mean time.
Thanx,
