matches_regex replacement
we are using an i-rule to perform some redirects for a site. A recent addition to the rule doesn’t appear to be working as we wanted it and I’m aware matches_regex is not the best solution so how can we replace this:
elseif { $uri matches_regex {^/(uk|test|news|marketing)/.*/$ }} {
    HTTP::respond 301 Location "https://www.company.com[HTTP::uri]default.page"
any advice appreciated.
thanks
A
Hi Andrew,
try this out:
    switch -glob [string tolower [HTTP::uri]] {
        "/uk*" -
        "/test*" -
        "/news*" -
        "/marketing*" {
Regards Andréas
Thanks Andreas, I might try that (we have a test environment). Someone also suggested using “ends_with” so might try that too like this, if I have the syntax right!:
elseif { [HTTP::uri] ends_with "/" } {
