I’m trying to setup a simple blacklist iRule to drop connections from clients with an IP that matches an entry in a DataGroup, and log the relevant entry. I use seperate Host and Network DataGroups for clarity.
However, matchclass isn’t returning any value other than 0 - thus connections are always allowed.
The problem statement(s) are (from the code block below)
set idxnet [matchclass [IP::client_addr] equals $::blacklistnet]
set idxaddr [matchclass [IP::client_addr] equals $::blacklistaddr]
If I delete the DataGroups and recreate them, the rule will work for one connection (ie. drops it), then it constantly fails (ie allows connections from a blacklisted machine).
when CLIENT_ACCEPTED {
log local0. “idxnet = $idxnet - ip = [IP::client_addr]”
if { $idxnet > 0 } {
set valnet [ lindex $::blacklistnet [expr $idxnet - 1] ]
log local0. “Subnet Blacklisted - [IP::client_addr] matched $valnet”
drop
return
log local0. “idxaddr = $idxaddr - ip = [IP::client_addr]”
if { $idxaddr > 0 } {
set valaddr [ lindex $::blacklistaddr [expr $idxaddr - 1] ]
log local0. “Address Blacklisted - [IP::client_addr] matched $valaddr”
drop
return
log local0. “Address Allowed - [IP::client_addr]”
The output I get (from the log statments) is -
: indexnet = 0 - ip = xxx.xxx.xxx.xxx
: indexaddr = 0 - ip = xxx.xxx.xxx.xxx
: Address Allowed - xxx.xxx.xxx.xxx
Any ideas?
(We’re running BIG-IP 9.4.1 Build 29.0)
