Marking false positive for Credit Card number (Data Guard)
Our ASM is flagging a value (d132c*****a6e5) that’s actually part of a name of a Java script on various URLs.
Is there a way to exclude this value, or mark this value as a false positive regardless of the URL?
Thx
Hello,
Its about Data Guard, isn’t?
If so, I try to set an exception pattern or defining an url list exception to bypass it.
Regards
Navigate to Security ›› Application Security : Data Guard and change the settings there. Select the policy and disable the options or add the ignore list.
Hope it helps.
-Jinshu
