We have and LTM virtual with an attached pool and an irule that references another pool. When the members of the attached pool are down but the pool in the iRule is up, the virtual stays up. Is there a command we can put in the iRule to down the virtual when the attached pool is down?
Nope… But what you could do is put a monitor on the default pool that checks the pool the iRule references… [e.g. An external monitor or a built-in transparent monitor - but you’d need one of those per member of the iRUle referenced pool)
H
I think it really depends on what you mean by “down”. If you mean that you don’t want to send any traffic to the iRule-referenced pool based on availability of the attached pool, then you could use the active_members command:
If, however, you need the VIP to be disabled completely, perhaps so that GTM will see it as down, then you could use an iCall (or raw user_alert.conf script) to effectively disable the VIP by triggering TMSH commands on Syslog monitor events.
If you use a Traffic Policy instead of an iRule on v12.1.2 you don’t get the same behavior as the irule. The VS goes down even if the path-match pool is up. I have successfully tested. Hopefully F5 doesn’t screw it up in a new OS version to make Traffic Policies more like iRules.
In version 13, when you drop all pools in traffic policy - the VS does not goes down(. Maybe i miss something. Dan Please show your settings.
Hi Alexander, What I am trying to achieve is the opposite of that. We drop the default pool, and the VS goes down, even if the policy has a pool that is passing healthcheck. I just tested this out in the lab on a v13.0.0 HF3 VE and the behavior is consistent with v12.1.2. Hope this helps.
root@(DCO-F5VE-LAB-3)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm policy
ltm policy test_policy {
controls { forwarding }
last-modified 2017-12-05:08:25:42
requires { http }
rules {
test {
actions {
0 {
forward
select
pool https_pool_anoel1
conditions {
0 {
http-uri
path
contains
values { /admin }
status published
strategy first-match
root@(DCO-F5VE-LAB-3)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm poo
ltm pool http_pool_default {
members {
dcosvrlab-1:http {
address 10.15.60.43
session monitor-enabled
state down
dcosvrlab-2:http {
address 10.15.60.44
state down
dcosvrlab-3:http {
address 10.15.60.45
state down
monitor failing-monitor
ltm pool https_pool_anoel1 {
members {
dcosvrlab-1:https {
address 10.15.60.43
state up
dcosvrlab-2:https {
address 10.15.60.44
state up
dcosvrlab-3:https {
address 10.15.60.45
state up
monitor tcp
root@(DCO-F5VE-LAB-3)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm virtu
Components:
virtual virtual-address
root@(DCO-F5VE-LAB-3)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm virtual
ltm virtual test {
destination 1.1.1.1:http
ip-protocol tcp
mask 255.255.255.255
policies {
test_policy { }
profiles {
http { }
tcp { }
source 0.0.0.0/0
translate-address enabled
translate-port enabled
vs-index 2
}`text`
Thank you Dan. Now I understand!
