I try to map legacy application requests coming in on a TCP port on F5 to a HTTP GET request and send it to backend application server
Response should then be send back to TCP Port.
BTW: This is a migration to F5, was done before on IBM Datapower.
Someting like this below. First part works, i.e. get request and build http request from. But how to handle the HTTP requests/response then ? Any hint ?
Jonview XMLMapper Socketserver Rule - build and sent HTTP GET request to XMLMapper application server
when CLIENT_ACCEPTED {
log “SocketRequest [TCP::collect] from client [IP::client_addr]”
TCP::collect
set internalhost “10.1.29.102:9081/”
set hardpath “jonview_host/connectionview?”
set usercred “userid=AAAA&password=XXXXX”
set clientip “ipAddress=[IP::client_addr]&”
when CLIENT_DATA {
log “Payload received: [TCP::payload]”
set httprequest “http://$internalhost$hardpath$clientip$usercred&message=[TCP::payload]”
log “request built: $httprequest”
so far ok, but now how to send HTTP request to pool, and handle response back to TCP Port …?
pool AsTestKob01
TCP::release
Regards
Urs
The simplest thing would be to just replace the incoming payload entirely:
log "SocketRequest [TCP::collect] from client [IP::client_addr]"
TCP::collect
set hardpath "/jonview_host/connectionview?"
set usercred "userid=AAAA&password=XXXXX"
set clientip "ipAddress=[IP::client_addr]&"
when CLIENT_DATA {
log "Payload received: [TCP::payload]"
set httprequest "GET $hardpath$clientip$usercred&message=\"[TCP::payload]\" HTTP/1.1\r\nHost: myhost\r\nAccept: */*\r\n\r\n"
log "request built: $httprequest"
TCP::payload replace 0 [TCP::payload length] ""
TCP::payload replace 0 0 $httprequest
TCP::release
Where the incoming payload may look something like this (broken out for readability - assume \r\n characters used for newlines):
GET / HTTP/1.1
User-Agent: curl/7.16.4
Host: 10.70.0.196
Accept: */*
You’ll replace it with this:
GET /jonview_host/connectionview?ipAddress=10.70.0.1&userid=AAAA&password=XXXXX&message="GET / HTTP/1.1 User-Agent: curl/7.16.4 Host: 10.70.0.196 Accept: */* " HTTP/1.1
Host: myhost
Accept: */*
You don’t have to include the full URL in the request or pool statement because all of the traffic will be going to the pool assigned to the virtual server. Here are a few additional considerations:
1. Assuming it’s your intention to send the FULL TCP request payload (method, headers, and all) to the server, I’d think you might want to at least URI-encode the (malformed) message query string, but that I suppose depends on your application.
2. If the client is sending properly formatted HTTP requests, and you DON’T need the full TCP request payload, but rather just the HTTP payload (everything after the HTTP headers), then this would all be much easier to do with HTTP commands.
thank you Kevin,
I’ll give it a try.
> 2. that is not the case. I know it would be easier that way.
Urs
