Map Class to Node
Hey,
I’m migrating an environment from 4.5 to 9.0. The 4.5 environment uses the map class to node function under Node Select Expression to map connections to the node they were originally connected to. We are parsing the weblogic cookie and mapping based on a unique value. Anyone know how I can do this in version 9???
Node Select Expression Value in 4.5:
mapclass2node(getfield(http_cookie(“WebLogicSession”), ‘/’, 2), plmqa-2050_class)
Sample Class File Content:
plmqa-2050_class
String
52456140 3.32.106.204:2050
52456141 3.32.106.205:2050
52456142 3.32.106.206:2050
52456143 3.32.106.207:2050
52456144 3.32.106.208:2050
Thanks in advance!
I will try this tomorrow!! One other question. We have 23 applications that are on the same VIP, but 23 separate ports. We have 23 separate class files as well. And this is all done 3X for QA, Load Test, and Prod. Is there an easy way to remove the port from the class file, so I can have one class file for everything instead of one per VIP?
Thanks again!!
Chris
Yes, you can leave the : part out of the class and then add it in the iRule. Something like this assuming the destination port is the same:
   set id [getfield [HTTP::cookie "WebLogicSession"] "/" 2]
   node [findclass $id $::plmqa_2050_class " "] [TCP::local_port]
