Folks, We are running F5 version 11.5.1 HF7 and have an ASM policy in learning mode. I see some violations been triggered under the “Manual Traffic learning” screen, BUT then if i come back to it after a few minutes, they are gone. Would like to know why the ASM does this? If a violation was triggered, it should stay there for ever until you either accept or clear it.
Have you seen this sol The BIG-IP ASM system may remove learning suggestions earlier than expected for high-traffic environments
Might not explain your environment however, if you’re not seeing high volumes of learning suggestions.
I’d double check /var/log/asm too.
Hope this helps,
N
