I have a couple questions I would like to run by the MP developers if possible:
1. I would like to know if there is truly a dependency on administering the F5 agents from the physical Mgmt server where the agent was discovered and installed from. The webcast " Tutorial - F5 Management Pack: DMS Discovery" indicated this to be the case. Does this mean you need to physically be logged into the Mgmt server to remove the agent?
2. The MP installation documentation says that discovery needs to occur from the RMS server see below. But in the webcast stated above, the discovery and installation was done from the 2nd Mgmt server. Please clarify which one is correct.
Note - You must run discovery from the Root Management Server you installed the F5 Management Pack onto. You can use Remote Desktop or Terminal Services, but discovery will not work from another Management Server or the Web Console.
3. What are the specific rights needed for the MP installation account and the Service account? The documentation says domain admins for the installation account, but this seems like overkill. Also what SQl rights does it need specifically?
