Managing Ramcache Entries with Pycontrol
A DevCentral user posted a question in the forums asking for verification of an attribute on the RamCacheKey structure. The maximum_responses attribute should be a long integer. With his C# code, the maximum_responses returned from his iControl call is always double the setting. I fired up pycontrol to see if this was a bug, and in my pycontrol code, I received the expected responses. While he’s taking a look at his code and the .Net library he’s using, I took an interest in the ramcache methods as I have not messed with the Ramcache module much. In this article, I’ll build out a pycontrol script that will enable users to query/evict ramcache entries.
The Interface
The iControl interface for querying/evicting Ramcache entries is RAMCacheInformation. The methods I’ll handle in the script are:
There are two more methods defined:
Preparing the BIG-IP
Beginning in v11, the ramcache configuration was removed from the http profile and moved into its own under Local Traffic->Profiles->Services->Web Acceleration. I created a profile called lcache with a parent profile of optimized-caching, increasing the cache size to 25 MB and decreasing the max age to 3600 seconds for testing. I left all the other settings default.
Apply this profile to an http virtual and a pool member with some content and I’m ready to move to the iControl work.
Building the Script
Because there are multiple actions in this interface I want to address, I’ll use command line options to control the script flow:
  • Host – (-H) Required
  • Username (-u) Required
  • Get Entries (-g) Profile Required
  • Get Exact Entry (-x) Profile, Host and URI required (as a white-space separated list in quotes. Ex. “lcache 10.10.20.60 /images/img1.png”
  • Evict Entry (-E) Profile, Host and partial URI required
  • Evict Exact Entry (-X)  Profile, Host and URI required
  • Evict All Entries (-A) No arguments necessary, empties the ramcache
With that plan in place, I can configure the parser options, shown in the following code snippet:
1:  from optparse <span style="color: #0000ff;">import</span> OptionParser
2:
3:  parser = OptionParser()
4:  parser.add_option("<span style="color: #8b0000;">-H</span>", "<span style="color: #8b0000;">--host</span>", action="<span style="color: #8b0000;">store</span>", type="<span style="color: #8b0000;">string</span>", dest="<span style="color: #8b0000;">host</span>")
5:  parser.add_option("<span style="color: #8b0000;">-u</span>", "<span style="color: #8b0000;">--user</span>", action="<span style="color: #8b0000;">store</span>", type="<span style="color: #8b0000;">string</span>", dest="<span style="color: #8b0000;">uname</span>")
6:  parser.add_option("<span style="color: #8b0000;">-g</span>", "<span style="color: #8b0000;">--get</span>", action="<span style="color: #8b0000;">store</span>", type="<span style="color: #8b0000;">string</span>", dest="<span style="color: #8b0000;">get</span>", help="<span style="color: #8b0000;">Supply profile name</span>")
7:  parser.add_option("<span style="color: #8b0000;">-x</span>", "<span style="color: #8b0000;">--get_exact</span>", action="<span style="color: #8b0000;">store</span>", type="<span style="color: #8b0000;">string</span>", dest="<span style="color: #8b0000;">get_exact</span>", help="<span style="color: #8b0000;">Supply profile name, host, and URI</span>")
8:  parser.add_option("<span style="color: #8b0000;">-E</span>", "<span style="color: #8b0000;">--evict</span>", action="<span style="color: #8b0000;">store</span>", type="<span style="color: #8b0000;">string</span>", dest="<span style="color: #8b0000;">evict_entry</span>")
9:  parser.add_option("<span style="color: #8b0000;">-X</span>", "<span style="color: #8b0000;">--evict_exact</span>", action="<span style="color: #8b0000;">store</span>", type="<span style="color: #8b0000;">string</span>", dest="<span style="color: #8b0000;">evict_exact</span>")
10:  parser.add_option("<span style="color: #8b0000;">-A</span>", "<span style="color: #8b0000;">--evict_all</span>", action="<span style="color: #8b0000;">store_false</span>", default=False, dest="<span style="color: #8b0000;">evict_all</span>")
11:  (options, args) = parser.parse_args()
12:
13:  <span style="color: #0000ff;">if</span> (options.host is None) or (options.uname is None):
14:   <span style="color: #0000ff;">print</span> "<span style="color: #8b0000;">\n\tHost (-H) and username (-u) must be supplied, exiting...</span>"
15:   <span style="color: #0000ff;">sys</span>.<span style="color: #0000ff;">exit</span>()
Now that the options are in place, we need to act based on the options provided
1:  <span style="color: #0000ff;">if</span> options.get is not None:
2:   rce = getRAMCacheEntries(rc, options.get)
3:   <span style="color: #0000ff;">print</span> rce
4:
5:  elif options.get_exact is not None:
6:   rce = getRAMCacheExactEntry(rc, options.get_exact)
7:   <span style="color: #0000ff;">print</span> rce
8:
9:  elif options.evict_entry is not None:
10:   rce = evictRAMCacheEntry(rc, options.evict_entry)
11:   <span style="color: #0000ff;">print</span> rce
12:
13:  elif options.evict_exact is not None:
14:   rce = evictRAMCacheExactEntry(rc, options.evict_exact)
15:   <span style="color: #0000ff;">print</span> rce
16:
17:  elif options.evict_all is not None:
18:   rce = evictRAMCacheAllEntries(rc)
19:   <span style="color: #0000ff;">print</span> rce
20:
21:  <span style="color: #0000ff;">else</span>:
22:   <span style="color: #0000ff;">print</span> "<span style="color: #8b0000;">No options selected!</span>"
23:   <span style="color: #0000ff;">sys</span>.<span style="color: #0000ff;">exit</span>()
In this code, I’m checking for the options and if none are set, I’m exiting. For each option, I’m calling a function to operate on that particular action. I’m passing the iControl object (see code below) and the argument list (“profile host uri”) as necessary to each function.
1:  b = pc.BIGIP(
2:   hostname = options.host,
3:   username = options.uname,
4:   password = upass,
5:   fromurl = True,
6:   wsdls = ['LocalLB.RAMCacheInformation']
7:  )
8:
9:  rc = b.LocalLB.RAMCacheInformation
For all the functions except the one to handle evicting all ramcache entries, I need to create an object for the RamCacheKey structure. This is done in pycontrol with the typefactory. Once the structure is created, I just need to add the appropriate attributes as defined in the API: profile_name, host_name, uri, and maximum_responses. The first three are strings, the last is a long integer. So the code is very similar in each function:
1:  rc_key=obj.typefactory.create('LocalLB.RAMCacheInformation.RAMCacheKey')
2:
3:  key_attr = rc_info.<span style="color: #0000ff;">split</span>(' ')
4:  rc_key.profile_name = key_attr[0]
5:  rc_key.host_name = ''
6:  rc_key.uri = ''
7:  rc_key.maximum_responses = 100L
I split the arguments to get each attribute isolated, then assign as appropriate. For a general get, I only need the profile name so I set the host and uri to an empty string. I chose 100 as a max response just to pick something. Now that the structure is defined, I can make an iControl call, in this case, to get all ramcache entries, then I return those values from the function to the variable making the function call above.
1:  rc_entry = obj.get_ramcache_entry(keys=[rc_key])
2:  <span style="color: #0000ff;">return</span> rc_entry
So if I put all this together, I can issue this command at the command line, with the data below returned:
C:\Users\jrahm\PycharmProjects\pyControl_Scripts>python ramcache_manager.py -H 10.10.20.5 -u admin -g lcache
Please enter the password for user admin
Password:
[[(LocalLB.RAMCacheInformation.RAMCacheEntry){
   profile_name = "lcache"
   host_name = "10.10.20.60"
   uri = "/images/gnome-64.png"
   vary_type = "RAM_CACHE_VARY_NONE"
   vary_count = 1
   hits = 0
   received = 1326237864
   last_sent = 1326237864
   expiration = 1326241060
   size = 4677
 }, (LocalLB.RAMCacheInformation.RAMCacheEntry){
   uri = "/images/ad_remoteauth_ssh_1.png"
   vary_count = 1
   hits = 0
   received = 1326237873
   last_sent = 1326237873
   expiration = 1326241069
   size = 16304
   uri = "/images/ad_descr.png"
   vary_count = 1
   hits = 0
   received = 1326237818
   last_sent = 1326237818
   expiration = 1326241014
   size = 17942
Now, if I want to evict one of those, I can change my options a little and try again, then do another query:
C:\Users\jrahm\PycharmProjects\pyControl_Scripts>python ramcache_manager.py -H 10.10.20.5 -u admin -E "lcache 10.10.20.60 /images/ad_descr.png"
Password:
None
Password:
   vary_count = 1
   hits = 0
   size = 4677
   vary_count = 1
   hits = 0
   size = 16304
You can see that the entry is now gone. And finally, If I evict all:
C:\Users\jrahm\PycharmProjects\pyControl_Scripts>python ramcache_manager.py -H 10.10.20.5 -u admin -A
Password:
None
Password:
Conclusion
There is access to great power via the iControl interface of your BIG-IP. With just a few lines of code, you can manage the ramcache from the CLI. For the full script, please check out the RAMCache Manager wiki page in the iControl codeshare. Happy Coding!
