I get this message in this menu: Access ›› Authentication : Local User DB : Instances
The “Create new instance” button is grey. I am on an active standalone device though…
APM version 15.1.6.1.
Any idea?
Do you by chance have a device-group defined for this standalone device?
tmsh list cm device-group
If so, delete this and test again.
No device group, no.
cm device-group device_trust_group {
auto-sync enabled
devices {
bigip1 { }
network-failover disabled
cm device-group gtm {
devices {
bigip1 { }
Any chance it WAS part of an HA pair or sync-group, and then disconnected?
No it has always been standalone. I managed to create a database with a TMSH command, but not a user ![]()
So interestingly enough, after testing a few things I ended up the same error message. But I was able to clear it with a reboot.
FWIW, the CLI syntax for create a localdb user is this:
ldbutil --add --uname="bob" --password="pass" \
--instance="/Common/my_test_db" \
--user_groups="" \
--login_failures="0" \
--change_passwd="0" \
--locked_out="0" \
--first_name="" \
--last_name="" \
--email=""
