Management IP's
Hello ALL,
I do have a silly question and i am new to F5 Prodcuts.
I do have 3-DNS sitting facing the internet and all i need is how is it configured so that guys from outside cann’t access and i see guys sitting inside are accessing.
My setup is 3-DNS interface is connected to external switch which is connected to INTERNET, so this box is visible to external world.
I also checked the config on /etc/hosts.allow, don’t find any host IP’s.
Thanks in advance for your assistance.
Any change you have a firewall between the your 3DNS and the Internet?
/CB
As bmbhatt suggests, it’s ideal to have a firewall between the BIG-IP (or 3DNS) and any insecure network). It’s also recommended to use the mgmt port (interface 3.1) to administer the units. Ideally, you’d have the management port on a discrete internal subnet not reachable from any public network.
You can configure which ports are open/need to be open on the self IP addresses using the port lockdown configuration. For more info on port lockdown, check SOL7317 (Click here).
Aaron
