Malformed Paket in tcpdump
Dears Good Morning,
I have an issue that Backend server i can connect directly but cannot connect through F5 VS …
VS configured to listen in 443 and have Client SSL Profile and http profile ( note that issue remain even if i remove the SSL profile to simulate connection as directly to backend server )
when i tried to see tcpdump i found the following
what is malformed packet mean and this is capture for direct connection to backend server
Ether frame seq check is not big-ip related. Please refer to wireshark forum instead
Decode the traffic is SSL and show what is hidden under PSH, ACK
