How do I make the satdby unit to active, so that the existing active device becomes standby
Advance thanks for your reply
Veeram
Active box, management gui. System - High Availability and on this screen you can click on Force to Standby
Active box, command line. Run “b failover standby” or “run /sys failover standby” if using tmsh v11 see “DevCentral”
Hope this helps
N
