Maintenance URL by iRule
is it enough for Maintenance URL from abc.com..?
when HTTP_REQUEST { HTTP::redirect “http://www.abc.com/maintenance.html” }
If you already have a maintenance.html page on the site, then I would use this
when HTTP_REDIRECT {
    if { not ([HTTP::uri] equals "/maintenance.html") } {
        HTTP::redirect "http://www.abc.com/maintenance.html"
Otherwise, you would have an endless loop because it’s not checking if you’re already on that page.
If you want a iRule based maintenance page, the Codeshare page has some examples of that.
Hi Micheal,
Thank you..please find updated
when HTTP_REQUEST { if { not ([HTTP::uri] equals “/maintenance.html”) } { HTTP::redirect “http://www.abc.com/maintenance.html” } }
Hi Michael,
is it when HTTP_REDIRECT
or
when HTTP_REQUEST
Because “when HTTP_REDIRECT” is not accepting. and error as below
Exception caught in LocalLB::urn:iControl:LocalLB/Rule::create() Exception: Common::OperationFailed primary_error_code : 17236305 (0x01070151) secondary_error_code : 0 error_string : 01070151:3: Rule [/Common/Maintenance_iRule_4] error: /Common/Maintenance_iRule_4:1: error: [unknown event (HTTP_REDIRECT)][when HTTP_REDIRECT { if { not ([HTTP::uri] equals “/maintenance.html”) } { HTTP::redirect “/maintenance.html” } }]
sorry. mistype… it’s HTTP_REQUEST.
Updated: The other option would just use the uri, which would look like this instead…
        HTTP::redirect "/maintenance.html"
we have made the below iRule and it is working…but images are blocking. images are in /images/
can we exclude images by conditions…?
Try this then. If you want to add more exceptions, just append them to the first set of URI checks (the
denotes an additional value is on the next line). The
-glob
allows the use of wildcards (the
character). So in this case, anything starting with
/images/
will be caught in that condition.
    switch -glob [string tolower [HTTP::uri]] {
        "/maintenance.html" -
        "/images/*" {
             Do nothing. These are exceptions
            return
        default {
