Expanding on @arpydays’ answer, the conditional clause is incorrect in a few ways. I’m reproducing your code here in a marked up block with comments after:
sets the timer to return client to host URL set stime 10
Check if the URI is /maintenance
switch [HTTP::uri] {
"/maintenance" {
Send an HTTP 200 response with a Javascript meta-refresh pointing to the host using a refresh time
HTTP::respond 200 content \
Sorry! This site is down for maintenance." "Content-Type" "text/html"
return
If the respective pool is down, redirect to the maintenance page else
send the request to the respective pool
if { [ string length [HTTP::host] eq test.com ] && [ active_members test_PROD_V ] < 1 } {
log local0. $host
HTTP::redirect "http://$host/maintenance"
return
[ pool test_PROD_V ]
You have used the evaluation operator (the square brackets -- […]) in a number of places where it will have an unintended effect and will produce runtime errors.
To explain, the evaluation operator assumes its contents are a valid Tcl statement and evaluates it, substituting the result of the evaluation in place of the operator. From there, normal Tcl processing continues. So, let’s say you do this:
if { [string tolower [HTTP::host]] eq “test.com” } {
the runtime expands inside-out. So, HTTP::host is evaluated first. That command results in a string. Let’s say that it yields the value “test.com”. If so, after this first expansion, the statement now looks like this:
if { [string tolower test.com] eq “test.com” } {
The remaining evaluation operator is expanded, yielding this:
if { test.com eq “test.com” } {
The runtime then executes the if command. That’s what you expect and want. But let’s consider your final statement:
[pool test_PROD_V]
This evaluates the pool command, which results in something (I’m not sure what it is, but I’m guessing it’s a integer). Let’s assume it is an integer. After the expansion, you’ll have something like this:
1
Well, the runtime treats every line as a statement. Every statement is a command followed by one or more argument. So, it tries to evaluate the command called “1”. There is no such command, so a runtime error is thrown.
It’s important to understand that the evaluation operator is not needed to force Tcl to execute a command. Every time Tcl sees a line, it will treat it as a command followed by zero or more arguments. The evaluation operator is only needed when you want to have Tcl evaluate a command that is embedded inside of a statement.
Given all of this, your if clause should look like this:
if { [string tolower [HTTP::host]] eq “test.com” && [active_members test_PROD_V] < 1 } {
and, as I say, your final statement should simply be:
pool test_PROD_V
