Joern
1
Hi Guys,
we want to use the machine tunnel to just connect the clients wit split tunnel to some license servers.
I installed nearly all components and set up the tunnel in registry.
Machine Certificate/Info is not working and there is created several apm/ltm sessions.
Is there more information about troubleshooting/configuring machine tunnel? Is someone successfully using the machine tunnel without edge client?
Thanks and stay relaxed/safe,
Sunny regards,
Joern
Samir
2
FYI,
I am sure you have added below things.
- Always connected mode
- Location DNS List
- DNS Proxy services
Joern
3
Thank you ver much for your reply.
Always connected mode is not in use - cause we want to use only machine tunnel w/o the edge client…
Is that even possible?
Samir
4
It looks good to me. Did you see any issue?
Joern
5
The ressource assignment is working and the client with machine tunnel is getting Access_Policy_Result=LTM APM_Mode;"
Every minute there is coming a new session - and the client can’t reach anything in the tunnel
Joern
7
anyone using machine tunnel?
