Machine Cert auth issue
Hi all,
I am using Machine Cert Auth Agent and the evaluation of the APM profile is failed and point directly to ‘fallback’ I get this line on repport:
<< machinecert_auth_ag.result’ set to ‘-2’>> COnfiguration of the agent is as following:
Certificate Store Name: MY Cert store location: LocalMachine CA prfoile : CA_Profile Saved certificate in asession variable: Enabled Allow user Account control right elevation: Yes Match subject CN with FQDN : No Match SAN with FQDN: Match issuer: CN=server1,DC=F5trn,DC=com (for server1.F5trn.com) Match serial number:
I am doing test on a PC with french language and the repository where the certificate is stored is called (Personnel) should I use this value or leave MY for the Certificate Store Name ?
On access system logs, I find “machinecert_auth_ag.result’ set to ‘-2’” . Do you have a list of the possible values with the meaning regarding the MachineCert_Auth_ag ?
Regards,
