if i just want to do reverse proxy for internet based clients. then i need to follow the “Using a single BIG-IP LTM as a reverse proxy for Lync Web Services” chapter. it makes two remarks about what you be turned on / off
1) Yes to “Would you like to create a BIG-IP virtual server to act as a reverse proxy for Lync external web services?”
2) No to “Are you deploying a reverse proxy as part of your Edge topology?”
well 2 is a bit unclear for me as you first need to enable either the front end or director server part. but does that mean you have to also enable fill in and use that front end / director server part? because if i understand the situation and the further text in the chapter fine then it is just a matter of replacing the single IP from the "What is the port 443 virtual server IP address that forwards traffic to the Front End Servers? " question into the front end server IPs. can’t imagine i need all the further front end or director server part.
