Lync edge servers using newest iapp template
Hi!
We are unsure on how to procceed with the deployment of our lync edge servers. On our edge servers with have on certificate on the external nic and one on the internal nic. Should we export these certificates and import them to the adc and use them in the iapp or should we use some other certifcate?
Regards
I would export and use the same certs. What I did personally was got one cert with all the SAN names for everything we are using. Also make sure to add the chain, or import the root CA manually into the ca-bundle.
