We are currently starting to configure our new environment in preparation of migrating over in the next few months.
Issue:
I am trying to deploy Lync 2010 using the current iApp. I have run through the template and everything comes back healthy, VIP, Pools, Nodes are all green and look good. When I have my messaging administrator try to connect to the VIP it just hangs and tells him that he cannot logon. If he points his lync client back to the VIP on the old environment it works as expected. Now in the old environment we did have to create some SNAT pools in order to get this working. Using the iApp template it sounds like that is only needed if your going to have over 64,000 connections or something along those lines. We will not have that many users. However, I went ahead and created SNAT pools manually anyway and added them (trying to duplicate the current setup) but he still could not connect. Before I start mucking around with changes, I though it best to reach out to the community for some guidance. I am hoping something can steer me in the right directions with this. Thank you in advance.
hi Soap, are we talking about internal or external clients? Lync is highly sensitive to routing issues. Are you using the same set of Lync servers and if so, are the routes configured correctly on those servers? Are the new BIG-IPs showing requests in the VIPs statistics page when the message admin tries to log in?
Can you describe the error you see when testing (if any) in more detail please?
Considering you have both old and new environments in place I’m pretty sure this is a routing issue where the servers are configured to route traffic back to clients via the old F5 pair. Check the servers and confirm if there are static routes configured for the SNAT range (of course it could rely on a default)? Use a new/unique SNAT range on the new F5 pair and configure statics routes on the servers for that range pointing to the new pair. You get the idea…
We were only testing internal connectivity, but yes, the FE’s do handle traffic for external clients also once they are handed off from the edge servers. I am told that there are no configured routes on the FE servers. I also do see accepted connections on port 5061 for the FE and Director VIP’s when we have tried to test.
I would run the logging tool on the FE servers. Once the initial connection has been made from client to VIP, the FE servers return a list of servers to connect to and all further communication happens between the clients and FE servers directly. I would make sure that they can route to each other, and that the FE servers are sending back the right list of servers. I believe you can see this by enabling verbose logging on the Lync client itself.
Okay, just to post an update, last night I went ahead and re-configured the template to remove any manual settings we had put in place regarding SNAT pools, etc. To my surprise this morning when I came in connectivity through the director and FE’s were working as they should. Scratching my head on this because initially when we tested yesterday before making any changes to the template this was not working. Going to do some more testing of features today and tomorrow and will report back.
EDIT:
I am noticing that the lync_consolidated_edge_external_ip_http_monitor monitor that was created from the template has all of my nodes marked offline. From what I am reading on other forums this monitor may never work and I might need to just use a TCP monitor. I wanted to run this past the forum as if this was the case I would assume someone would have reported it by now. I am trying to search through the forums but I seem to always return ZERO results. Must be doing something wrong…
Are you using the version of the iApp avaialble on DevCentral: DevCentral
This newer version uses TCP monitors for the Access service pools and also has quite a few bug fixes; for example, the VIP for this service uses an HTTP profile in the old template, which will not work.
I was using the template that was already on these brand new 4000’s. I assumed it was the latest. Let me download this other one and make sure. I assume this is a newer one.
That’s correct. Also, there are still a few post-configuration steps that you must take (which are detailed in the deployment guide). We are working on an updated version that will include those fixes, and more, to be posted to DevCentral.
Looks like that did the trick, imported new template, made a few tweaks after the fact and everything is look good. Can’t believe I missed the whole template version thing. Thanks!
Hi Jerome, I have never seen that problem before, but it sounds like it might be a product bug in BIG-IP. What format was the cert/key in when you imported it onto the BIG-IP?
Hmmm, not really. The quickest thing to do would be to go back to the Lync servers and re-export the certificates as .pfx files, which contain both the cert and private key. Then you can re-import those into the BIG-IP and try again.
Reviving this old thread to see if folks have implemented any iRules or other controls to prevent password guessing at the network perimeter. All I get from Microsoft is a recommendation to use a filter produced for TMG.
Hi Michael, I saw the same article I personally did not succeed in protecting the DialIn login page with ASM because it used SAML to send credentials to the back-end servers (the POST request does not send username & password as parameters but an XML content). RFE 388564 was opened a couple of months ago to add this feature into ASM.
Looking for the same solution. TMG is now EOL, and Enterprises deploying MS Lync client on Mobile devices want to protect against brute force attacks and locking out the AD accounts.
