LYNC 2010 & F5 LTM V9.3.1
Can the deployment guide for F5 LTM V11 be used to configure an F5 device for a LYNC Consolidated Edge / DNS Load balanced configuration with LTM version 9.3.1, if not is there a deployment guide for version 9.3.1?
Hi, we haven’t tested Lync with BIG-IP version 9, although I can’t think of anything special we are doing that wouldn’t be supported with that version. Microsoft recommends not mixing DNS and hardware load balancing for Lync, though, so you may end needing to do all load balancing through the BIG-IP.
thanks
Mike
