LTM with Citrix XenApp or XenDesktop
Dears, Kindly when I use ltm for XenApp or XenDesktop , I red that f5 has (secure ICA proxy mode) which make it able to publish these application.
My question is this make any problem for accessing the application through mobile ? I think if F5 rewrite the ICA file then this may cause problems
In most cases, the rewrite is replacing the application server address with the BIG-IP virtual server address and adds a parameter to encapsulate ICA traffic within ssl. The STA ticket and specific session parameter information is not altered by default. I have not seen any mobile issue personally; what kind of issues do you suspect would be occur for mobile devices?
