LTM with BGP route advertisement
One more question to the group. Two Cisco router and a pair of LTMs in a dual homed environment. Each Cisco has it’s own uplink. All four devices communicate internal using iBGP, virtual servers are correctly advertised and the failover is working as expected. Each time I enable bgp in the route domain on both devices, the routing is screwed up, the virtual server is correctly advertised but i.e my snat adress is not.
Could anyone help here?
Best
Frank
Is the SNAT range attached to a VLAN? (In other words, does the F5 have an interface in that subnet?)
Yes, it is.
OK, so it should just get advertised without any specific work on your part. Is the SNAT related VLAN in the same Route Domain as the VLAN used to connect with the Cisco routers? Do any ACLs or Route Maps need to be adjusted on the Cisco side?
You might find this useful too for checking what’s in the kernel routing table and what’s advertised: 404 Page not found | BIG-IP Documentation
Yes it is advertised, as soon as I disable BGP on one node, everthing is working. “show ip route kernel” shows all virtual servers and the host route for the SNAT IP Address as well. If I enable dynamic routing again, the virtual servers are still reachable but the SNAT is out of order. Apart from that, each time the device is rebooted it loses BGP from the routing domain.
Disable BGP on one node? Can you explain that in more detail please. Same for “the SNAT is out of order” - I assume you mean you can no longer see it in the output of the ‘show ip route kernel’.
Regarding the reboots, do you mean the BGP module doesn’t run automatically for that RD on system startup?
Lastly, what version are you running?
On Node 1 - Network ›› Route Domains ›› 0 → remove BGP from Dynamic Routing Protocols → update, after that SNAT and virtual adresses are working and reachable from the internet. I’m also able to ping from the internal network to hosts on the internet.
On node 2 - [0]sh ip route kern. shows me the virtual server routes including the SNAT address
On Node 1 - Network ›› Route Domains ›› 0 → add BGP to Dynamic Routing Protocols → update, virtual servers are still reachable (even when I force the node to standby) but no SNAT
Version 11.2.1
cisco 1 123.123.55.241
cisco 2 123.123.55.242
node 1 123.123.55.243
node 2 123.123.55.244
node 2 with bgp enabled only on that node
show ip bgp 123.123.55.208
BGP routing table entry for 123.123.55.208/28
Paths: (1 available, best 1, table Default-IP-Routing-Table)
Advertised to non peer-group peers:
123.123.55.241 123.123.55.242 123.123.55.243
Local
0.0.0.0 from 0.0.0.0 (192.168.1.4)
Origin IGP, localpref 100, weight 32768, valid, sourced, local, best
Last update: Mon Oct 15 13:03:04 2012
node 2 after enabling bgp also on node 1
Paths: (2 available, best 2, table Default-IP-Routing-Table)
Local
123.123.55.243 from 123.123.55.243 (192.168.1.3)
Origin IGP metric 0, localpref 100, valid, internal
Last update: Mon Oct 15 16:48:03 2012
Local
and here the output from node 1
123.123.55.241 91.241.55.242 91.241.55.244
Local
123.123.55.244 from 91.241.55.244 (192.168.1.4)
Last update: Mon Oct 15 16:48:08 2012
Local
0.0.0.0 from 0.0.0.0 (192.168.1.3)
Last update: Mon Oct 15 16:48:02 2012
Both nodes shows the route as best path although the route is in the kernel table from node 1
sh ip route kernel
K 123.123.54.195/32 is directly connected, tmm0
K 123.123.54.196/32 is directly connected, tmm0
K 123.123.54.198/32 is directly connected, tmm0
K 123.123.54.199/32 is directly connected, tmm0
K 123.123.54.200/32 is directly connected, tmm0
K 123.123.54.201/32 is directly connected, tmm0
K 123.123.54.202/32 is directly connected, tmm0
K 123.123.54.203/32 is directly connected, tmm0
K 123.123.54.204/32 is directly connected, tmm0
K 123.123.54.205/32 is directly connected, tmm0
K 123.123.54.207/32 is directly connected, tmm0
K 123.123.54.208/32 is directly connected, tmm0
K 123.123.54.209/32 is directly connected, tmm0 <---- SNAT
K 123.123.54.210/32 is directly connected, tmm0
K 123.123.54.212/32 is directly connected, tmm0
K 123.123.54.213/32 is directly connected, tmm0
K 123.123.55.132/32 is directly connected, tmm0
K 123.123.55.133/32 is directly connected, tmm0
K 123.123.55.135/32 is directly connected, tmm0
K 123.123.55.136/32 is directly connected, tmm0
K 123.123.55.210/32 is directly connected, tmm0
K 123.123.55.211/32 is directly connected, tmm0
Are these devices in a HA pair, active/standby or completely independent? Are you using ConfigSync for the LTM configuration?
Do you have an IGP running too?
I take it the whole /28 is advertised to the Cisco routers. Do things look OK from that POV? Do they route to node 1 when BGP is enabled? Are they running an IGP?
Devices configured as an HA pair active / standby and yes the config is synced using the LTM GUI. No we don’t have an IGP running, only BGP between these for devices. The config on the Ciscos looks fine.
And in any configuration, do the Cisco routers get the correct routes advertised? If there’s no IGP I take it you’ve turned off synchronisation on the Cisco routers and you’ve configured next hop self? I’m far from a BGP expert so forgive me if the questions are way off field. Can you post the IMI configuration and also compare it between the two devices?
Also, did you change the SNAT Packet Forwarding setting you asked about earlier on both boxes, or check it’s synchronised?
Yes the cisco gets the correct routes advertised. Synchronisation is turned off by default in that IOS version. Each Cisco uses next hop self. Here is the whole config.
node 1
router bgp 12345
bgp log-neighbor-changes
bgp graceful-restart restart-time 120
network 123.123.54.0/23
network 123.123.54.0/26
network 123.123.54.64/26
network 123.123.54.128/26
network 123.123.54.192/26
network 123.123.55.0/26
network 123.123.55.64/27
network 123.123.55.96/27
network 123.123.55.128/27
network 123.123.55.160/27
network 123.123.55.160/28
network 123.123.55.176/28
network 123.123.55.192/28
network 123.123.55.208/28
network 123.123.55.209/32
network 123.123.55.224/28
network 123.123.55.240/28
redistribute kernel
neighbor 123.123.55.241 remote-as 12345
neighbor 123.123.55.241 next-hop-self
neighbor 123.123.55.241 capability graceful-restart
neighbor 123.123.55.242 remote-as 12345
neighbor 123.123.55.242 capability graceful-restart
neighbor 123.123.55.244 remote-as 12345
neighbor 123.123.55.244 capability graceful-restart
ip route 70.72.6.200/30 123.123.55.241
ip route 70.231.161.80/30 123.123.55.242
node 2
router bgp 12345
redistribute kernel
neighbor 123.123.55.243 remote-as 12345
neighbor 123.123.55.243 capability graceful-restart
cisco 1
router bgp 12345
network 123.123.54.0 mask 255.255.254.0
network 123.123.54.0 mask 255.255.255.192
network 123.123.54.64 mask 255.255.255.192
network 123.123.54.128 mask 255.255.255.192
network 123.123.54.192 mask 255.255.255.192
network 123.123.55.0 mask 255.255.255.192
network 123.123.55.64 mask 255.255.255.224
network 123.123.55.96 mask 255.255.255.224
network 123.123.55.128 mask 255.255.255.224
network 123.123.55.160 mask 255.255.255.224
network 123.123.55.160 mask 255.255.255.240
network 123.123.55.176 mask 255.255.255.240
network 123.123.55.192 mask 255.255.255.240
network 123.123.55.208 mask 255.255.255.240
network 123.123.55.224 mask 255.255.255.240
network 123.123.55.240 mask 255.255.255.240
neighbor 70.72.6.201 remote-as 5656
neighbor 70.72.6.201 route-map prepend out
neighbor 70.72.6.201 filter-list 1 out
neighbor 123.123.55.243 next-hop-self
ip forward-protocol nd
ip as-path access-list 1 permit ^$
no ip http server
no ip http secure-server
ip route 2.2.2.2 255.255.255.255 GigabitEthernet0/0
ip route 70.231.161.80 255.255.255.252 123.123.55.242
ip route 123.123.54.0 255.255.254.0 Null0
ip route 123.123.55.176 255.255.255.240 GigabitEthernet0/0
cisco 2
router bgp 12345
bgp default local-preference 150
neighbor 70.231.161.81 remote-as 1111
neighbor 70.231.161.81 filter-list 1 out
neighbor 123.123.55.244 next-hop-self
no ip http server
ip route 1.1.1.1 255.255.255.255 GigabitEthernet0/0
ip route 70.72.6.200 255.255.255.252 123.123.55.241
cisco 1
snat address
show ip bgp 123.123.55.209
BGP routing table entry for 123.123.55.209/32, version 11073552
Paths: (2 available, best 2, table default)
Advertised to update-groups:
6
Refresh Epoch 1
Local
Origin IGP, localpref 100, valid, internal
rx pathid: 0, tx pathid: 0
Refresh Epoch 1
Local
123.123.55.244 from 123.123.55.244 (192.168.1.4)
Origin IGP, localpref 100, valid, internal, best
rx pathid: 0, tx pathid: 0x0
cisco 1
some virtual server
show ip bgp 123.123.55.210
BGP routing table entry for 123.123.55.210/32, version 11079429
Paths: (1 available, best 1, table default)
6
Refresh Epoch 1
Local
Origin incomplete, localpref 100, valid, internal, best
the virtual server is correct announced but the snat address point to the standby device
Just for your own protection I assume you’ve masked any sensitive information? Some of the static routes look ‘real’.
On node 2 you’re missing ‘neighbor 123.123.55.241 next-hop-self’
On cisco 1 you’re missing ‘neighbor 123.123.55.244 next-hop-self’
Any reason for that?
Sure, all addresses are masked and unfortunately the missing statement is just a copy & paste error :frowning:
OK, here’s some more questions;
1) Anything in the /var/log/zebos.log and /var/log/daemon.log files?
2) When you do a ‘show ip route’ on node 1 does it show node 2 as the best path for the .209 SNAT address?
3) Can you get any more detailed output from show ip bgp x.x.x.x command that might explain the preference for node 2?
4) This from the ARM manual: “When using BGP, RIP, or IS-IS, both units of the redundant system automatically advertise their shared, floating self IP address as the next hop for all advertised routes. This ensures that peer routers use the shared self IP address as the next hop for all routes advertised by the BIG-IP system.” - You’re output suggests this isn’t the case? Is there no Floating IP?
Debug is enabled on both but /var/log/zebos.log contains no good informations, daemon log is also not very useful. Item 4 on your list helped me a lot. I was able to fix it. To solve the issue I created a floating self IP for the uplink interfaces on the bigip ips and changed the peering on the cisco boxes to only use the floating IP, after that it’s working :slight_smile:
Thanks for you effort and your time.
Best Frank
Phew, I was close to conceding defeat there. You’re very welcome and hey, I’ve learned quite a bit on the way myself.
