The traffic flow for this connection is:
DMZ(on firewall) 10.0.0.0/24 range -> hits a IP 192.168.1.x ->
SRC NAT(outgoing interface of the fw) and DST NAT (to VIP:8080) ->
NO AUTO MAP, Persistence used -> Loadbalanced across websense pool ->
reply goes back the same interface of the fw which was used for the src NAT IP.
In the pcaps from LTM, the VIP resets the connection after a GET from the src NATTED IP. And the reset from the LTM only says “TCP retrasmission timeout”.
From read this thread: DevCentral - An F5 Technical Community
It seems that the TCP profile low time out value could be as issue here but I’m not sure and not sure how to test this.
On another note I feel the SRC NATTED address on the fw interface is exhausting its limit of 64k ports and hence the LTM is failing to respond in time.
What troubleshooting approach can I go to from here. Just started with f5s.
Thanks.
