ltm pool webmail.ironmountain.com-443 { members { kcmtmgp01.na.xxx.com:https { address 192.x.x.x session monitor-enabled state up } } monitor /Common/https_443
But when we try accessing the URL from external network it doesn’t work and keeps loading. Upon taking a packet capture I could see Reset packets from LTM VIP to Default Gateway on LTM.
Looks like it’s a HTTPS virtual server but you’re not offloading the SSL transaction. In that case remove the http profile from the VS configuration and try again.
OK, two further things, see 404 Page not found | BIG-IP Documentation to log the RST reason. Also, try using SSLDUMP to check if it’s the SSL handshake failing (I assume if you use TCPDUMP it passes the initial TCP 3 way handshake?)
When I take a tcp dump I see the 3 way handshake and then some tCP Retransmision packets. Some TCP Duplicate and Keep Alive PAckets in middle and then Reset from LTM VIP to Default Gay=teway configured on LTM.
