LTM version for Viprion 11.2.1 -> best?
We are running 11.2.1 and wonder what others are running on their Viprions. We had stability problems on Viprion 2400 with 11.1 but 11.2.1 seems to be a happy place. We aren’t seeking any new features, just avoiding getting too far behind. 11.3 seems mature with plenty of hotfixes. Suggestions? Thanks! -P
Hi!
We are running 11.2.1 on ours (no vcmp) and it worked fine for our needs for quite some time until our devs wanted to introduce web sockets so we are upgrading to 11.4 (also, I’m very curious to try the proc feature :slight_smile: ).
/Patrik
If you are not after new features, you are better off staying put. v11.3.0 has a shorter lifetime, being a .0 release, and there are already signs that issues are fixed in a hotfix for v11.2.1 but there is no correspondent release of fixes for v11.3.0.
Thank you for the suggestions. I think we’ll stay put, tracking hot fixes in 11.2.1.
