LTM VE 10.2 ships with only one volume populated, HD1.1. Is there a way to just duplicate HD1.1 to HD1.2? Can’t apply a hotfix in the active volume and there aren’t any other volumes configured. Trying to avoid downloading the 10.2 iso…
Updates can be applied to BIG-IP VE with a package known as a hotfix.
Since the VE disk is pre-created and designed to be as svelte as possible, the base version iso image is left out. The trade off for having a lighter weight deployment is that updates have an extra task of importing an iso image onto the VE before the hotfix can be applied.
Here’s the BIG-IP 10.x hotfix solution guide:
Here’s a Solution Guide on the topic of importing a base version iso image before installing a Hotfix:
