I am prepping to upgrade our LTM HA pair from version 9.4.6 to 11.3
I Know I have to go to 10.x first but do Ineed to apply the 10.x hot fixes before upgrading from 10.x to the final destination of 11.3?
Hi JB what version of 10.x you have specifically?
However I recently upgraded few pairs from 10.2.1 to 11.3HF4 (F5 said that 10.2.3 would be a good option to choose) and following are the mandatory changes to take care about:
Modifications/Changes required in existing configuration:
“matchclass” needs to be replaced with “class match” (Reference: DevCentral)
Example:
Old syntax
if { ![matchclass [HTTP::method] equals $::safe_http_methods] }
Required syntax
if { ![class match -- [HTTP::method] equals $::safe_http_methods] }
Also in case you are using some variables like string arrays then you may modify them to a string class for better manageability (a good to have option)
Old syntax
Required syntax with “safe_http_methods” as a class
if { ![class match -- [HTTP::method] equals $safe_http_methods] }
The class/data-group will look something like:
ltm data-group safe_http_methods {
records {
DELETE { }
GET { }
HEAD { }
OPTIONS { }
POST { }
PUT { }
type string
Follow this while upgrading:
Also the failover configuration is totally different in 11.x so you need to create the failover again, following KBs should help:
SOL13649: Creating a device group using the Configuration utility http://support.f5.com/kb/en-us/solu…13649.html
SOL13639: Creating a device group using the Traffic Management Shell http://support.f5.com/kb/en-us/solu…13639.html
v11.3.0: Manual Chapter: Creating an Active-Standby Configuration Using the Setup Utility http://support.f5.com/kb/en-us/prod…3-0/2.html
Let me know if you need more clarity on specific areas
Ajmal
No. you can skip hotfixes. ![]()
