LTM to GTM - Second set of self IPs using same Vlan
Is it possible to have a second set of self IPs in a different range using the same vlan in the LTM and GTM.
Currently
VLan Outside - Tag 111 - Interface 1.1
F5-1 1.1.1.1 (floating) - 1.1.1.2 Self F5-2 1.1.1.1 (floating) - 1.1.1.3 Self
F5-1 2001::1 (floating) - 2001::2 Self F5-2 2001::1 (floating) - 2001::2 Self
Looking to add using the same Vlan…
F5-1 2.1.1.1 (floating) - 2.1.1.2 Self F5-2 2.1.1.1 (floating) - 2.1.1.3 Self
F5-1 2002::1 (floating) - 2002::2 Self F5-2 2002::1 (floating) - 2002::2 Self
Thanks,
Hi
Your issue looks similar to this one below to me :
Check if it helps you :slight_smile:
Regards, Vik
