We need to downgrade a lab LTM for some testing to 9.3.1. I have not obtained any accurate or useful information from my F5 case yet (Case C1060625).
From TM Shell, can I execute/run the following command to accomplish the downgrade:
install sys software image local-install-9.3.1.37.1.im
When trying to launch the .im executable from CLI (not in TMSH), I get the following message:
[root@toc-lab1-2-6800:Standby] tmp im local-install-9.3.1.37.1.im
Logical volume disk management detected.
Non LVM-aware media detected.
---- ERROR: installation cannot proceed. ----
This system is using logical volumes for disk management,
but the media you are using (/shared/tmp/local-install-9.3.1.37.1.im) does not contain an LVM-aware product.
If you need to install non LVM-aware products, please refer to SOL9745.
This system will first need to be reformatted into a partitioned layout.
Note that the ‘image2disk’ utility cannot be used to install releases
earlier than 10.0.0 or 9.6.1.
I’ll be referencing this solution article, but it doesn’t state anything about v11, so thought I’d post to see if anyone has had any experience with this.
Thank you in advance,
Chad
