Thanks for your response , kindly note that when i install the certificates on the physical server and bypass the F5 , i can login to the server without any issues
here is an SSLsump 172.32.31.200 is the IP address of the virtual server and 10.255.155.137 is my IP. , .
[root@EMP-LTMASM-1:Active:In Sync] tmp ssldump -nr /var/tmp/www-ssl-client.cap
New TCP connection 2: 10.255.155.137(50487) ↔ 172.32.31.200(443)
New TCP connection 1: 10.255.155.137(50488) ↔ 172.32.31.200(443)
1 1 0.0041 (0.0041) C>S Handshake
ClientHello
Version 3.3
cipher suites
TLS_RSA_WITH_AES_128_CBC_SHA256
TLS_RSA_WITH_AES_256_CBC_SHA256
TLS_RSA_WITH_RC4_128_SHA
TLS_RSA_WITH_3DES_EDE_CBC_SHA
Unknown value 0xc027
Unknown value 0xc013
Unknown value 0xc014
Unknown value 0xc02b
Unknown value 0xc023
Unknown value 0xc02c
Unknown value 0xc024
Unknown value 0xc009
Unknown value 0xc00a
TLS_DHE_DSS_WITH_AES_128_CBC_SHA256
TLS_DHE_DSS_WITH_AES_256_CBC_SHA256
TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA
TLS_RSA_WITH_RC4_128_MD5
compression methods
NULL
1 2 0.0042 (0.0000) S>C Alert
level fatal
value handshake_failure
1 0.0042 (0.0000) S>C TCP FIN
2 1 0.0048 (0.0048) C>S Handshake
ClientHello
Version 3.3
cipher suites
compression methods
NULL
2 2 0.0049 (0.0000) S>C Alert
level fatal
2 0.0049 (0.0000) S>C TCP FIN
1 0.0060 (0.0018) C>S TCP FIN
2 0.0069 (0.0019) C>S TCP FIN
New TCP connection 3: 10.255.155.137(50489) ↔ 172.32.31.200(443)
New TCP connection 4: 10.255.155.137(50490) ↔ 172.32.31.200(443)
3 1 0.0034 (0.0034) C>S SSLv2 compatible client hello
Version 3.1
cipher suites
SSL2_CK_RC4
SSL2_CK_3DES
Unknown value 0xff
3 2 0.0035 (0.0000) S>C Alert
level fatal
3 0.0035 (0.0000) S>C TCP FIN
4 1 0.0034 (0.0034) C>S SSLv2 compatible client hello
Version 3.1
cipher suites
TLS_RSA_WITH_3DES_EDE_CBC_SHA Unknown value 0xc013
TLS_DHE_DSS_WITH_AES_1 28_CBC_SHA
SSL2_CK_RC4
SSL2_CK_3DES
Unknown value 0xff
4 2 0.0034 (0.0000) S>C Alert
level fatal
4 0.0034 (0.0000) S>C TCP FIN
3 0.0053 (0.0018) C>S TCP FIN
4 0.0051 (0.0016) C>S TCP FIN
New TCP connection 5: 10.255.155.137(50491) ↔ 172.32.31.200(443)
New TCP connection 6: 10.255.155.137(50492) ↔ 172.32.31.200(443)
5 1 0.0032 (0.0032) C>S SSLv2 compatible client hello
Version 3.0
cipher suites
SSL_RSA_WITH_RC4_128_SHA
SSL_RSA_WITH_3DES_EDE_CBC_SHA
SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA
SSL_RSA_WITH_RC4_128_MD5
SSL2_CK_RC4
SSL2_CK_3DES
Unknown value 0xff
5 2 0.0032 (0.0000) S>C Alert
level fatal
5 0.0033 (0.0000) S>C TCP FIN
6 1 0.0033 (0.0033) C>S SSLv2 compatible client hello
Version 3.0
cipher suites
SSL2_CK_RC4
SSL2_CK_3DES
Unknown value 0xff
6 2 0.0034 (0.0000) S>C Alert
level fatal
6 0.0034 (0.0000) S>C TCP FIN
5 0.0052 (0.0019) C>S TCP FIN
6 0.0050 (0.0016) C>S TCP FIN
New TCP connection 8: 10.255.155.137(50494) ↔ 172.32.31.200(443)
New TCP connection 7: 10.255.155.137(50493) ↔ 172.32.31.200(443)
Version 2 Client.
8 0.0031 (0.0031) S>C TCP FIN
Version 2 Client.
7 0.0043 (0.0043) S>C TCP FIN
8 0.0047 (0.0016) C>S TCP FIN
7 0.0058 (0.0015) C>S TCP FIN
