I have the following LTM configuration. VLAN1-external , VLAN2 and VLAN3 internal. There are several virtual servers configured, and also an forwarding IP vs in order for the LTM to behave as a router(which works very well…the only thing is that I cannot access for example from VLAN3 the local and floating IP from VLAN 2, but I can access any other machine in VLAN2).
The virtual servers configured on the LTM cannot be accessed from the internal VLANs(vs configured to load balance in vlan 2 can be accesed from VLAN2 but not from VLAN3).
the only thing is that I cannot access for example from VLAN3 the local and floating IP from VLAN 2, but I can access any other machine in VLAN2is this what you are seeing?
sol3475: The BIG-IP system may not respond to ICMP ping requests for a self IP address
The virtual servers configured on the LTM cannot be accessed from the internal VLANs(vs configured to load balance in vlan 2 can be accesed from VLAN2 but not from VLAN3have you run tcpdump to see what is going on?
It was a missconfiguration from my part. The virtula servers were configured to be active on strict vlans.
Anyway on the same deployment there seems to be a problem with ssh connections that go through the F5. I tried creting a separate virtual server to handle the ssh connections and set the idle timeout to a higher value, but did not have any efect.
