LTM Question
Hi Folks,
Is there any way I can configure a health monitor to search for a specific string and if that string not available, mark the pool member up.
Example: F5 LTM should check for .xyz Domain Names | Join Generation XYZ and if the return string is ‘OutofService’, bring the server down. For all other return strings keep the member live.
Thanks.
Hello,
Check the “Receive Disable String” feature :wink:
Hope it helps
Regards
